fs, kicker zx300.1
  • 1
cookboy
kicker zx300.1
decent little amp. works 100% looks 9/10. it's dusty in the pic from sitting on the shelf. it is in great shape.
RMS Power
150 watts x 1 @ 4ohm
300 watts x 1 @ 2ohm
$55 + shipping
plus shipping
513
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
cookboy
cookboy
endicott, ny
cookboy
Brendon Jenness
    May 8, 2024
    May 8, 2024
