Quantum Audio QCA3000D Mono Amplifier
momofx
IL, USA
In great working condition. Missing two screws on the output channel which do not affect anything since its a mono amp and the two other screws are still there.
◦1 x 1500 RMS @ 1 OHM
◦120A FUSE RATING
◦Top of the line Components
◦Heat Management System
◦Built in sub-sonic filter
◦High Efficiency Mosfet Power Outputs
◦Built in Low Pass CrossOver - adjustable at 12 dB per octave
◦Illuminated Logo
◦Class A/B
◦frequency response: 20-28KHz
◦(2) 60A Fuses
◦THD: .05 %
◦S/N Ratio: Greater than 95 dB
◦Input voltage: 11 - 14.4 volts
◦Adjustable Input sensitivity: .2 MV - 5V
◦bass boost control @ 45 hz - 12 dB
◦1 ohm stable
◦1 x 3000 watts @ 1 ohm
◦1 x 1500 watts @ 2 ohms
◦dimensions: 16.92" x 2" x 11.5" inches
$100 Shipped with Tracking!
Payment via Paypal. Sold as is.
Pictures below.
Ill check it out. I was actually on the site last week. Thanks!
206
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
247
16
663
momofx
momofx
IL, USA
Sprinkin8tor
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
