12" Alpine Type R's cut out
Noob@Bass
I recently purchased two 12" Alpine Type R's (SWR-1222D) subs and an 1100 watt RMS amp (Alpine MRX-M110). I have them wired for a 2 ohm load i believe. I can only turn my amp gain to about 1/8 turn up and my subs will cut out at 18 volume. I know these subs can handle more than that and I don't know what to do. Maybe my wiring is for a 4 ohm load? Help
take a picture of how you have them wired. If you don't know exactly how you have them wired, you need to.
That is how you should have those subs wired.
I checked and that's exactly how they're wired. So I'm assuming I have them wired correctly. I was trying to set my gains and before I even hear distortion my subs cut out. That's on 3/4 volume and about 2/5 turn up on gain.
Sounds like its possible there's a bad connection either your power or ground wire to the amp causing the amp to go protect due to being starved for power under heavy load. Check all connections be sure there's no paint on any metal surfaces and that all connections are tight.
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
87
This weekend I will be taking actual pictures for other sites. So grab it before its gone
6
524
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
5
554
Noob@Bass
Noob@Bass
North Dakota
The Audio Guy
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
