DD 9518 Info
  • 4
skrilla22
Getting my first DD sub soon, as well as my first 18 incher. Just looking to hear some opinions on enclosure size/port size/tuning.
Will be powered by an AB VFL 150.1 in the back of a Ford Explorer, so you have some room to work with. What's the best 5-7 cubes tuned to 32 or is that too low? How much port area?
Tried searching but I didn't come up with much, thanks in advance for your opinion!
I've done several of them for daily: 6 cubes net, 96^2 port area, and tuned 35-36Hz. If that amp is only 1500watts you could go bigger, 6.5 - 7cubes net and do 16^2 port per cube.
Base tuning on the music you'll mostly listen to. I've never tuned AQ/DD subs below 34Hz as they'll play into the upper 20's no problem at that tuning
The ab vfl 150.1 is rated at 2900rms ..but wont do so unless ur running .5 with strong electrical ..safe to say around 2200 to 2500
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
542
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
skrilla22
skrilla22
Tacoma, Washington
hispls
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
