Hpf & lpf
hotrod351
24
arizona
this is probably been asked 100s of times, but here goes again. LPF ans HPF settings, i search omline and find answers for settings them both to 80HZ to setting the LPF to 80HZ and the HPF to 100HZ or even 120HZ. im running three amps, one for door speakers, pioneer 6.5" and one for my two 8" JL audio subs. ive tried both settings but seem to go back to 100HZ for the HPF. my LPF is 80HZ.
LPF for your subs should be around 80hz in rare cases sometimes 100hz but most people usually don't like the sound. If your doors aren't deadened or the speakers are low quality you may prefer a higher HPF due to a limited amount of mid bass. All in all it boils down to what sounds good to you, not just some rule of thumb that you need to follow.
thats the feeling im getting for all the settings. get a basic setting and go from there. really it sounds good to me now. leave it alone and enjoy. thanks
tried 120 and 100 on HP and 100 sounds best to me. seems it all depends on speakers, speaker location and how your hearing is.
Hpf set to 80hz door speakers really shouldn't play lower than that without specific design inputs ie: sealed doors, fully deadened doors, mounted...
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
203
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
235
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
185
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
423
hotrod351
hotrod351
arizona
hotrod351
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
