sub goes crazy for a couple seconds... amp into protect... suggestions?
spencer321
palm bay
checked the power and ground... its steady, plus my highs amp is off the same distro block one foot away and that amp is perfectly fine. Pulled the sub, Dual 4ohm coils read 3.9 on each coil, checked and double checked all my wiring, it all seems fine, the only thing i haven't gone through is the signal wire itself... is it possible for a short or a bad signal wire to cause this problem?
symptom: turn the car on plays fine for a minute, then a couple really loud pops and protect
no its the amp... i started workin on it, been disconnected for a few days, now it goes straight into protect, so i disconnected everything and hooked it straight to the battery and jumped the remote to the positive, straight into protect...
so i opened up the back of it... what am i looking for? or should i just pitch it and say to hell with it?
Take the amp to a car audio shop and get them to test it in front of you...Some charge nothing at all..my advice to you..Best buy/local shops/ect???
I know steve at Ampmedics can fix it for you. It will be WAY cheaper then gettin a new amp. Great guy who does amazing work, just google Ampmedics
yeah i opened it up, didn't see anything burnt, i looked over every part of it very carefully but i also don't know what im doing, i just looked for burnt spots or broken solder connections and didn't see any
271
357
The best shallow that I've heard is the JL by far. One good regular 8" sub on a 1K would probably be all that you need. Two 8's in 1.5 cubic feet...
506
429
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
330
spencer321
spencer321
palm bay
spencer321
    May 10, 2024
3toneEYZ
    May 10, 2024
