kicker 10"l5 in factory enclosure
  • 1
SCIVIC94
if it isnt broke,modify
10" kicker l5 in factory ported enclosure. wired for 2 ohm load.
rated at 450 watts rms / 900 watts peak
enclosure measures 21.5 wide x 15" tall x 10 " depth bottom x 6 3/4" depth top
Item(s) Description/Condition: item is in decent condition. it is a bit dirty but nothing major. no tears,chunks missing or structural issues.
110 picked up in elizabeth nj 07201
130-145 shipped depending on state.will be shipping from 07057 wallington nj
will meet depending on distance.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
357
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
894
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
SCIVIC94
SCIVIC94
ELIZABETH , NJ
SCIVIC94
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
