Kicker ANL fused distro block..3 fuse slots!!
  • 1
wu501
N.Y
Kicker ANL fused distro block, (5) 1/0 or 4 gauge in, (3) 1/0 or 4 gauge out.
This thing is massive, it has (3) anl fuse slots.
Free shipping to any of the lower 48 states.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
492
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
983
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
wu501
wu501
N.Y
wu501
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
