Amp for my IDQ 12" V3 Dual 4 Ohm
  • 6
gangstajpimpin
Hello,
I recently fried my Alpine MRP-M500...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I would like recommendations for my Image Dynamics 12" Version3 Dual Voice Coil 4 Ohm subwoofer and maybe a perfect voltage to set the output gain to :p
Thank you and sorry for being n00b...im tired of having to replace things //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Also, here are the specs of the woofer...so u dont have to look it up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
RE: 1.35/5.4 Ohms
FS: 26.241 Hz
QES: .469
QMS: 2.609
QTS: .397
VAS: 2.98 cuft
Xmax: 18 mm
SD: 519.45 cm2
SPL: 87.01 dB
RMS Power Handling: 50-600 Watts
Reccomended Enclosure Size (Sealed Box): 0.65-1.0 cu.ft
Mounting Depth: 5.8"
I would like to keep the price relatively low...but i want the amplifier to take a beating...i will never purchase another alpine amplifier again...i go full tilt all day long and they cant handle it
Id reccomend the ID Q600.1 or a jl 500/1
if you went with an ID 1200.1 you could always expand later. at two ohms you'll get about 800 watts just watch your gain and volume control then later you could add another and have 1200 watts at 1 ohm //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
192
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
227
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
172
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
414
gangstajpimpin
gangstajpimpin
Las Vegas, NV
revrider1
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
