Depends on the class you want to run. Like they said agu's are popular but if you run a class where you can use 80 amps or more then I would choose anl's there are some anl fusses you can pass quite a bit of current through. For instance I have found some anl 80 amp fuses that will pass over 250 amps of current consistantly.
