Fiberglass Help
  • 4
pr1dragon88
Platano Ranger
122
Miami, Fl
im about to build a custom fiberglass set up for my 2 15" comp vr's...then it occured to me...what about the spare tire? if i go through with this will my spare tire be unaccessable..cuz this is a daily driver so i need that option...any ideas or help would be great
There are ways to make the spare tire accessable. It depends on what kind of car though as to how to accomplish it. Sssssooooooo........what kind of car ya drive? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ahhhh.......... the civic. most I have done were simply a false floor with the enclosure attach to it. And the false floor attach to the car with a piano hinge. You can motorize it if you like also . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah man. A false floor is simply a piece of wood 1/2" - 3/4" thick depending upon the weight of your enclosure. That is cut in the shape of your hatch floor. Take a compass and trace the perimeter of your hatch floor on some cardboard, and make yourself a template. Then trace your template on your wood. And get to cutting //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Once you got that done. You can attach it with a piano hinge right behind the back seat. Then build your enclosure on the false floor. leave yourself some sort of handle to lift it with.
or yu could relocate your spare to a different part of the hatch. To me the false floor is easier. But others like to move it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks for the help..is there anything else i should know about that....i'll keep it simple, the car is alright tight as it is...i keep the tire where its at
If you use a hinge. make sure you don't drill into the gas tank. It will be right under the area your working //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Only problem there is if he ever gets a flat its a big pain in the ass to unhook your amp and pull out your box in order to get to your spare. Trust me I had to do this along side I-79 one time.
Me too and it ain't no freakin fun //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif especially if your enclosure is heavy as most //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
3K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
287
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
280
pr1dragon88
Platano Ranger
pr1dragon88
Miami, Fl
kingpin_jeffie
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
