Kicker L7 Duel 4 ohm
Originally posted by Jmac Large as possible, ported, and tuned to a little under your vehicle's resonant frequency with the largest port possible ...
i thought you want it tuned a little over the RF so everything doesnt rattle like a mother
Take a sub, an SPL meter, a burnt CD with a delayed sweep from 40-80 Hz and a sealed box that is larger than the Vas of the sub and measure where's it's the loudest (Note, you don't need to push the sub to its limits and Radioshack meters will only measure to 120 dB ...)
That will give you a rough estimate...but you need something that reads higher to get real RF values...
365
900
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
rollinhard22s
rollinhard22s
Coopersville MI
rollinhard22s
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
