HELP!!..problems with kenwood double din deck!!!
  • 4
hey guys...im a new member to this website...i have a kenwood double din cd player which used to play both copied and original cds...all of a sudden, i dont know why but it plays original cds perfectly and 65% of the times just ejects my copied cds...when it miraculisely reads copied cds, it only reads till track 4 or 5 and then just shuts up and doesnt even read at all..some ppl told me it cud be one of the following, i tried it all, but its still the same:..
-burn at 4x
-different program
-different burner
ive tried all but its still the same...please help me out guys...
thanks
ab
*ps...just a reminder...original cds run perfectly no matter what...its only the copied ones that
I would have to agree that something is wron with your burnt cd's....otherwise the cd player wouldn't play any cd's at all.
hey guys...im a new member to this website...i have a kenwood double din cd player which used to play both copied and original cds...all of a sudden, i dont know why but it plays original cds perfectly and 65% of the times just ejects my copied cds...when it miraculisely reads copied cds, it only reads till track 4 or 5 and then just shuts up and doesnt even read at all..some ppl told me it cud be one of the following, i tried it all, but its still the same:..-burn at 4x
-different program
-different burner
thanks
ab
it used to play them...now it doesnt correct? maybe just throw that bish in the trash?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You're not using crappy Staples cd's or something are you? Only issue I ever had with burnt cd's (besides having to burn them at 4x to avoid skipping) was that sometimes on really cheap cd's the outside ond inside edge aren't completely smooth...check to see if either of those 2 are rough around the edges.
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
212
183
driftking01
driftking01
Perth, Australia
ProgMtl
    May 22, 2024
    May 22, 2024
