Are this dimensions okay?
  • 3
streakz
Are these specifications okay?? It's a vented Trapezoid enclosure:
Height? = 20 Inches
Width? = 18 Inches
Depth1? = 6 Inches
Depth2? = 18 Inches
If the above dimensions are OUTSIDE dimensions, enter the thickness of the wood below.
Wood Thickness? = .5 Inches
Speaker Displacement? = 1 Ft³
Port Frequency? = 35 Hertz
Port Diameter? = 2 Inches
Number of Ports? = 1
Sq. Port Ratio H:W? = 1:
Data Output:
Box Front Angle = 59 Degrees
Gross box volume = 1.056 Ft3
Net box volume = 1.047 Ft3
Port Length = 5.102 Inches
Port Area = 3.142 Inches2
Port Volume = .009 Ft3
What should I change to improve it?
Most people run bigger wire than they need. It won’t hurt anything and is actually recommended here. Those reducers work great but I’d recommend...
681
streakz
streakz
New York, NY
violator5spd
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
