Fiberglassing Help
  • 3
jeeper07
Rebuilding&Reconstruc ting
Well i have just started my first fiberglass job //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif so far its been fun cause i like doing new projects. Any way my question is, even if my matt is overlapped should i/ is it normal to do 2 layers. I am REPLACING the kick panel not just adding a speaker enclosure so it needs to be sturdy. I dont know how hard it gets etc but i was wondering if 2 is needed or if one will do fine ill have pics after a while
fiberglass forums does a good job of answering this.. in essence...if you can push it in with your thumb (make it flex with that lil pressure) then you need to add more
To my knowledge, I have only heard clipping being attributed to amplifier inputs; power and signal. If your input signal is weak and you turn up...
7
99
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
167
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
185
11
405
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
261
jeeper07
jeeper07
Indianapolis, IN
jeeper07
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
