Alpine D-Aux and Aux output help
  • 1
skeides
I've got an alpine cda-9851 and I wan't to hook up my labtop to the audio inputs (I believe they're inputs) so that I can play my mp3 library while driving in my car. They're three audio ports on the back of the headunit one is for subwoofer i'm sure of, the others say "L" and the other says "R". Not sure what these markings mean, but when I hooked into the audio ports labeled "R" i could hear some music, but when i turned up my labtop volume as well as my car volume the volume level on that audio port was still very weak. I've been hooking up the volume output to the headphone jack output on my computer. I'm not running an amplifyer in my car.
Also looking on my headunit I can select between D-aux and Aux. Aux was what I was getting the very low audio from. thanks in advance
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
106
This weekend I will be taking actual pictures for other sites. So grab it before its gone
532
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
555
skeides
skeides
Fullerton
skeides
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
