TS parameters for 02 Kicker l5?
yeah. thanks for the very constructive and useful information.. It really makes my day batter. Because you think so I obviously must not have checked. It must be because you have 13,XXX posts and I have 2XX that I am incapable of looking for myself and that your first reaction should be to break forum rules and flame someone instead of leaving well enough alone with a blank response. That said. It is possable that I missed it. But all I found was archived info on other forums with a couple of them conflicting each other. So sorry for asking in a Enclosure design section about the T/S parameters of a sub. This is clearly not the right place to gain useful information.
Bassbox pro requires many t/s parameters some of which arent on the skar audio website. This is my first time searching for t/s parameters online...
463
955
DarkFox
DarkFox
Old Lyme, CT
DarkFox
SlugButter
    May 4, 2024
slater
    May 2, 2024
