enclosure plans for orion 12 h2 needed...will pay
  • 2
i'm currently building a box for two of them at the moment. It's a dual chambered box. I can just split it in half, but it'll be a deep box. it would be 29" deep x 18.38" wide x 14" high. 32hz. it'll be possible to change it around. did you try the sticky of plans?
I can go as big as i want really,. But my max area i want to dedicate to it is, 36w x 15t x 15d. Single 12 dvc 4ohm wired to 2ohm with 800watts...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
591
rippinitup7
rippinitup7
ohio
James Bang
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
