Sold Zapco Studio 300x
usamps
Brand new Studio 300x. Never got around to using it. White. $300 shipped within the 48 states. Pics are below.
Specs:
Specifications
Output Power 150 watts/ch @ 4 Ohm, 20Hz-20kHz
230 watts/ch @ 2W, 20Hz-20kHz
T.H.D. + Noise S/N Ratio >105dB
Dynamic Headroom .6dB @ 2 ohm load
Separation >70dB
Damping Factor >700 @ 4 ohms, 350 @ 2 ohms
Input Type Fully balanced differential REF GND
Input Sensitivity .25 - 5.0 Volts, variable
Maximum Input Level 10 Volts R.M.S.
Input Impedance 20K ohms
Crossover Range 30Hz - 720Hz
Crossover Slope Low Pass 12dB, 24dB/octave
Hi Pass 12dB/octave
Hi Pass T.H.D. + Noise Hi Pass Separation >85dB
Hi Pass S/N Ratio >120dB
Maximum Output Level 10 Volts R.M.S.
Power Requirements 60 Amperes max. @ 2 ohms
Fuse Rating Dual 20 Amperes - Automotive blade type
Minimum Load 2 ohms stereo
Idle Current 1.6 Amperes
Dimensions 16”L x 5-7/8”W x 2-1/2”H
MODERATORS!!! I'm 99% certain that this seller is none other than CHRIS JONES. He is pushing awefully hard to sell this amp. He posted this up on the Zapco forum and it has been deleted. John Bourges of Zapco even made a post about it. I hope I'm wrong, but the description given by the Zap forum member 8000x (that's right) is an almost exact match with this description.
To the seller, if indeed I'm wrong about this, please accept my apologies. I might even be tempted to buy the amp from you if you're legit. However I've rooted out scammer's before, and I've got a REAL strong feeling that you're out to burn someone....
What the HELL? I have NEVER signed up for the zapco forum for one thing. Another thing, are you BLIND?? Did you not check the feedback link I posted???
usamps
usamps
around
usamps
