Sold Zapco Studio 300x
usamps
Brand new Studio 300x. Never got around to using it. White. $300 shipped within the 48 states. Pics are below.
Specs:
Specifications
Output Power 150 watts/ch @ 4 Ohm, 20Hz-20kHz
230 watts/ch @ 2W, 20Hz-20kHz
T.H.D. + Noise S/N Ratio >105dB
Dynamic Headroom .6dB @ 2 ohm load
Separation >70dB
Damping Factor >700 @ 4 ohms, 350 @ 2 ohms
Input Type Fully balanced differential REF GND
Input Sensitivity .25 - 5.0 Volts, variable
Maximum Input Level 10 Volts R.M.S.
Input Impedance 20K ohms
Crossover Range 30Hz - 720Hz
Crossover Slope Low Pass 12dB, 24dB/octave
Hi Pass 12dB/octave
Hi Pass T.H.D. + Noise Hi Pass Separation >85dB
Hi Pass S/N Ratio >120dB
Maximum Output Level 10 Volts R.M.S.
Power Requirements 60 Amperes max. @ 2 ohms
Fuse Rating Dual 20 Amperes - Automotive blade type
Minimum Load 2 ohms stereo
Idle Current 1.6 Amperes
Dimensions 16”L x 5-7/8”W x 2-1/2”H
usamps
usamps
around
usamps
