Zapco SP7-SL Equalizer.
miller83815
Zapco SP7-SL
Like new, Works as it should. Comes with EQ, Power Supply and cord.
Will also trade for a mono amp 3K and up, can add cash for right amp. Please no junk !
Features:
Max. Output Level / Balanced: 16 Volts
Input Impedance: 10K ohms
Output Impedance: 600 ohms
T.H.D. + Noise:
S/N Ratio: 100dB
Frequency Response: 2Hz - 150KHz
Stereo Separation: >80dB
Dimensions: 3.25"L x 6.25"W x 0.95"H
SymbiLink™ Balanced Input
Can drive 600 ohm loads
Pro audio balanced differential Inputs
High quality PC board with ground plane
Very low noise & Distortion
Clipping LED’s monitor all 28 op-amps
1/2 DIN size
Surface mount technology
Separate gain switches for both input and output
Seven 1.25 octaves of Equalization
Can accommodate 8 volt (16 balanced) input / output signal levels
Very high quality, long life, low noise potentiometers
SP7SL - Zapco SP7 SL SymbiLink Seven Band EQ with Gain
$350.00 Shipped in the usa.
Does this only work with zapco amps, or is it compatible with other brands? With the new decks that have built in equalization, is this piece a much cleaner equalizer? Tell me why I need this because I am interested...
With the Included power supply, It will work with any amp.
A classic piece with great sound quality and transparency in sound with minimal coloration. All EQ bands boost and cut frequencies with a beautiful full sound and do not make the sound peaky and unnatural.
This is a great addition to any high quality system that will allow you to make quick EQ changes on the fly depending on the type of music you are listening too.
miller83815
Hayden, Idaho
miller83815
BP1Fanatic
BP1Fanatic
