Will upload pics of both amps tomorrow. The Zapco is brand new and the Planet Audio is in 9.5/10 Condition.
Zapco I-600 Brand new in box. Sells for $300 on woofersect. $150 shipped.
Specifications:
Mono Output @ 2 ohms: 1 X 750 Watts MAX
Mono Output @ 2 ohms: 1 X 610 Watts RMS
Mono Output @ 4 ohms: 1 X 430 Watts RMS
Remote bass boost control included
T.H.D. Distortion with 22k Filter
Frequency Response: 10Hz - 230Hz
S/N Ratio: >85dB
Dimensions: 13.5"L x 10.75"W x 2.25"H
SymbiLink" Balanced Input
Balanced line (speaker) input for OEM integration
Unbalanced RCA input
12dB Bass EQ at Full/LP at 45Hz
Variable electronic crossover
Planet Audio VX900D CLASS D MonoBlock Power Amplifier used for about a year, in excellent condition. Just a few scuffs around the mounting holes from screws. Have the box/manuals/receipt. $120 shipped
Specifications:
650WRMS x 1 at 2 ohms
955WRMS x1 at 1 ohm as per the birthsheet @ 13v
S/N: 105 dB
Frequency Response 20-250Hz
Damping Factor: 405
Crossover: Low Pass - 50Hz-150Hz, 24dB/Octave
Crossover: Subsonic (High Pass) - 15Hz-40Hz, 24dB/Octave
Bass Boost - 0 + 18dB
Phase Control (Switchable) - 0 to 180*
Input Sensitivity - 100mV to 2V
(2V to 8V COMPATIBLE)
Input Impedance - 10K-Ohm
Line Output Impedance - 100 Ohm
Dimensions (W x H x L) - 10 1/4" x 2 7/16" x 10 5/8"
Specifications:
S/N Ratio: >85dB
Specifications:
S/N: 105 dB
Damping Factor: 405
