SRT-10
Got VIPER power?
Ok, here is the set-up:
Dodge RAM SRT-10 Quad-Cab (BIG cab needs big volume - LOL...)
2 sets of Focal 165K2P's - one set in doors / A-pillars, the other set in the RAM-specific Q-Logic custom kick panels. The specs, (and my dealer) say the K2P's will take 100w "nominally", all day long. However, there is something I am a little un-clear on, so I am hoping that perhaps some the gurus amongst you can kind of "layman's terms" it for me.
These are 4-ohm component sets. Ideally, you would run each set off of one channel of a 4-channel amp. So, then I start to look at impedance and the correlating power rating increases of some of the different 2-channel amps, and I start to scratch my head...
First off, if you were me, would you run a solid 4-channel amp (like a 300/4) on these sets, and let them "play" at 4-ohms all day long, or would you look at running them off of an even higher-power 2-channel amp, taking advantage of the 2-ohm stability (and subsequent power level increases) all of the higher-end 2-channel amps offer...?
I am still a bit of a newb with some of this stuff - so bear with me here - but am I correct in assuming that if you were going to run four component sets off of a 2-channel amp, you would connect two component sets to channel 1 and two component sets to channel 2, thereby showing the amp a 2-ohm stereo load (on each channel)? Assuming that I am correct so far, then how is the 2-ohm rated power "distributed"...? I will use the Zapco DC350.2 here as an example - at 4ohms, it is rated at 2x100w. But at 2ohms, it is rated at 2x170w. Now, you have added an additional component set to each channel to get the 2ohm load, but is that power being distributed "evenly" - that is to say, is each component set getting approximately 85w?
Bueller? Bueller? Bueller?
