Zapco 1100.1 Excellent Example
wanderer1
Item(s) for Sale: Zapco 1100.1 mono sub amp ready to show and go
Reference Series Monoblock Class A/B Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 825 watts x 1 chan.
2 ohms: 1100 watts x 1 chan.
Dynamic power output: 1450 watts x 1 chan.
Optically isolated MOSFET power supply
High current bipolar outputs
E.H.V High voltage output circuitry
Remote bass level input (remote level control sold separately)
SLDIN-T.F Balanced line transmitter included
LED power (green) and clipping (red) indicators
Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
SymbiLink acts as a line driver and can boost signal input up to 12dB (4-times)
Improved noise rejection, lower system noise floor, reduced distortion, and up to 16V signal output
Input mode switch (left, right, L/R sum)
Mono channel operation
Slew rate: 40V/uS
Crossover x10 (550-5,500)
Transient distortion (4 ohm, 40W):
Heavy duty textured pewter finished aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation
SymbiLink balanced line inputs
Gold-plated RCA level inputs
Gold-plated high current screw terminals
Input sensitivity:
Balanced (DIN): 250mV-10V
Variable low-pass filter (55-550 Hz, 24 dB/octave)
Variable subsonic filter (24 dB at 15-50 Hz)
Damping factor: >700 @ 4 Ohm
CEA-2006 compliant amplifier
Frequency response: 20-20,000 Hz
Dimensions: 35"L x 7-1/2"W x 1-15/16"H
VERY VERY nice. 5 nicks in a heat sink fin is all I could find as far as physical flaws. 9.5/10 easy
Price: $550 Shipped and I paypal
N/A
Item Pictures: I probably could've wiped it down first but I didn't sorry.
PM me if there are any particular pictures you would like to see. Pretty sure I have the bass knob. haven't gotten to use this what a shame. Someone fire it up in a T/L box or somethin hard to drive, that's where the Zapcos excel.
wanderer1
wanderer1
Laughlin
wanderer1
