Your Suspension
either bag it or lift it...
My chevette sags pretty bad, have a deka 31, bl 18, and a 6 cube box in the back haha.
My buddies tib sags too with a deka, beast 12, dsc 1500, and a 2004 ap. pretty bad actually. Im about to upgrade my pontiac and im thinking about coil overs.
my acura mdx sagged really bad with 2 15" heavyweights and a few 100lb batteries. I would always get flashed by oncoming drivers who thought I had my brights on. My Honda Pilot is startin to sag too as I add more equipment. I'm not sure what my options are with that...
megan racing fully adjustable coilovers front and rear ( 32 position adjustability )
Hotchkis front and rear sway bars
Ichiba front control arms
ichiba rear camber arms
work vs xx 19" x 9.5" front O disk +17 and 19" x 11" rear O disk +10
225-35-19 front dunlop
245-35-19 rear dunlop
my battery and spare are in the back of my pontiac already so im thinking that itl handle the weight better. the trunk is well centered over the read axle. where do you guys buy your parts at, coil overs/sway bars, I wouldnt mind doing both to the lil ponty
I have stock self-leveling rear air suspension which surprisingly still works good after 172k miles.
The simplest way to add support for your suspension is to get stiffer springs.
I haz no springs in back //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Self leveling suspension is the **** though... used to have a work truck F-150 that had it still working with about 200k on it. We could haul 1500 lbs in back of that POS
how expensive are they? I don't really go around drifting my **** so I don't need anything high performance really just a little help with body sway. lol.
I also wanna go lower on my drop but I would have to get a camber kit if I go any lower. How hard was it to adjust your toe, camber, and caster?
stock coils with newer struts\shocks whichever it is in the back.
Don't really have much sag when my box and amp are in, maybe an inch? I'm only running 1 12" Mbquart in a ported box, not much weight.
nateberrier
nateberrier
Douche, Ohio
hatedonmostly
