Well I am ready to hook my amp up and have a question or two on the gain setting.
My HU is a Sony CDX-M630 with 2 volt pre amp subwoofer outputs and subwoofer volume control.
The amp is a Power Acoustik A2400DB which will be presented with a 1 ohm load.
I have read on bcae1.com to match the voltage from the HU with the gain on your amp.
I have also read the gain setting tutorial.
I plan on doing it by using a DMM and according to the formula in the tutorial I should set the gain until the speaker terminals on the amp reads 41.56 volts AC on the DMM.
Is that right?
Also I know that all EQ's should be in the off position loudness off,bass off but what about the subwoofer volume control?
Just making sure I am going to do everything correctly.
Is that right?
