yellow top batt?
i have a hc2000 and stinger 1750 and a gr31 yellow top can i put these in the back of my car its the only opition i have for finals or will it hurt to mix batts and would you use the yellow top in back
monitor them, I wouldnt do for the long term and I would also get a decent to good agm intelligent charger. If you can't buy at least barrow 1.
They can't discharge at the same speed, and react to charging differently. They also will have different resting voltages.
If it's just discharge, and their resting volts are almost identical, you should be fine... but I wouldn't cycle them low or charge them off of one alternator.
Will you be running with car on or off? Which event are you participating in at Finals? Is this for State or World?
its for state car will be running the resting volts are from 12.8 to 13voltswhen the car is running they all read 14.3 but thats becouse they are hooked together
You might get some funk when you first connect them, but I wouldn't sweat it.
Just make sure you have more than enough batts... cause when one runs low, it'll pull juice from the others.
Batts will be fine for short term use. The problem comes from when you have your car off the batts will be trying to constantly equalize their voltages which will shorten their lifespan if left for long periods of time.
The OP is really Fast85gt, he just made another account up because he is a loser and has nothing better to do than try an get on the same boards that he ripped people off on. What's even funnier is he is 38, has a family and still acts like a 12 y/o. Wait a minute that's not funny, it's just plain pathetic.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
pwnt.
mecaspl151
mecaspl151
sugervally
J31Rob
