Xxx ?
bamaboy
War Eagle!!!
well i got my XXX loud where i want it, had it there for about 2 weeks or so, i dont believe in using these but it made it loud like where i think it should be
1) turned on super bass eq and modded it a little
2) turned on loudness
3)rose sub output to +2
now when i turn these off like set to flat, sub to 0, and loudness of my bass dissappears, it pretty much goes away like it isnt there
now with loudness/eq on i usually keep the vol on like 12/40, and never turned it over 15/40, but when i check the settings with a 45hz tone im getting 62.1v on 14/40
when i turn off everything i get around 62v on like 25 or so/40 but i turned it down to around 44
now when i measure ohms i get 1.5, but i was told that okay, i was wondering if i can use 1.5ohms instead of 1 when i do the gain setting, i would get 54v
^these are using 2000rms, should i use 2300rms instead? if i use 2300 it would be 48v for 1 ohm
now if i set the gains by ear the gain would have to be up a good way for me to get the bass i think should come out of this, and its a 15 XXX and "2300rms"
now what should i check? i can try to use a viper 1200.1 and see how that works, or could it be my cd player?
i may get the clarion 955 and see how that does
it just dosent seem to hit the lows good
i have a friend with a old style L7 12 in a ebay box, and if he p[lays boyz in da hood it sounds better on the somewhat low note than on mine, i tried messing with the ss filter but it didnt change anything i really dont know what is up with this thing, i might just put it back on everything and leave it there and dont care about it because if i have to use the setting at 44v than i may have to sell it and get something else, that guys l7 surprised me with how loud it sounded
um...you can't check resistance on a circuit that has voltage on it...
and your box rise is a **** of alot higher then that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what do you mean voltage, i i unhook the wires from the amp how does t still have voltage on it?
so i just set the gain to "1" or what dont worry about imdependence(sp?) rise or what?
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
NDMstang65
