XXX ohms
bamaboy
War Eagle!!!
well took out my XXX to make sure everything was wired right, and checked ohms on coil to make sure they were fine, well both coils read 2.5/2.6, its supposed to be a dual 2 ohm, i want to know did it come from RE like that or did it alter it self?i never checked the coils when i put it in because i forgot to, when in parallel it read 1.5 ohms , i wanted 1 //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif , so for the gain setting should i base it on 1.5 ohms instead of 1, even thogh its gonna have imdependance rise in box, but should i use 1.5 ohms for gain or 1? the coils arnt going out are they?
That's DCR you're measuring...2 ohms is the "nominal" value, because the impedance changes depending on cone position.
*edit - n00b.
//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
*edit - n00b.
\Noooooo!!//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
please explain, is that right ? ima a nob when it comes to the complicated stuff //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif , but should i set my gain to 1.5 or leave it...haelp me
I wouldn't say nominal is the most accurate. Generally is just the closest whole number to actual impedance when the cone's in its neutral state (centered). Actual speaker impedance is dependant on frequency, so there is no over all average frequency for a speaker, it depends what its playing. Nominal impedance is basically used for advertising, and component matching.
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
audioholic
