XXX in a house
Do you even have to break these woofers in? I'll be getting an XXX soon so I want to be clear on break in. Is it necessary? Should I just install it in my car and play it low for the first day? or what?
Just play it like you normally would. Think about it; If you keep it low, how is it going to loosen up? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Just play it like you normally would.
Unless you normally get in and crank it to full tilt. Breaking in a sub usually isn't 'necessary', but its usually a good idea too. Most drivers Ive used from new had a break in period, and believe me it was noticeable. You do not want to drop in your new sub, sit in the seat and crank it. Play it reasonable the first few days, use your ears to listen for distortion, use your ears to listen for that distortion to lessen, and the output to rise as the suspension loosens. You can loosen the suspension without needing to drive the suspension to its limits, or even anywhere close.
well ive been driving around since tuesday
with my new SE's getting less than 300watts
as a "break in"
i drive less than an hour a day...
about how long should i keep them down???
i did my refresher on gain setting today
thanks to the sticky... but i dont know
how long to hold out...
i absolutely trust your opinions and advice... but
any reason in particular??? it seems reasonable
that the subs would need some time to loosen
up a bit... it also seems reasonable that the subs
wouldve been tested sometime during my 25 day
waiting period...
and sqeak... since ive got you on the line... any
advice on dampening the trunk??? what to use?
if to bother? where to put it?
Like I said above, use your ears. When the subs start to distort, turn it down. You will find this threshhold will rise as the suspension loosens. Break-in just means use your head, your ears and your common sense.
edit: if you doubt the need for a break-in period, go read a few professional reviews of subs in some magazines. Pratically all of them list how and for how long they did a break-in period before actually starting the tests. Must be something to it...
i absolutely trust your opinions and advice... butany reason in particular???
Well; First off, if you don't use the sub (i.e. play it at a reasonably loud level), then you are absolutely wasting your time. Barely using the sub (keeping the volume down) isn't going to do anything to help "loosen" it. Second, the sub will loosen up just fine during normal operation. Just use it like you planned on using it. Unless you are pushing the sub to it's absolute extreme (which, sorry, but you won't do that with music at typical listening levels), then you have nothing to worry about. Just play the sub now how you would play the sub a year from now.
and sqeak... since ive got you on the line... anyadvice on dampening the trunk???
Use layer upon layer of sound deadening //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif 2-3 layers on every surface is what I'd aim for if I were you.
what to use?
Raammat - http://www.raamaudio.com/products.htm (what I use)
Secondskin - http://www.secondskinaudio.com/secondskin.html
Brown Bread
Seem to be the most used
Absolutely. You will do nothing but benefit from sound deadening. Put it everywhere; trunk (every wall/floor/trunk lid/rear deck if it's rattling), floor of the car, doors, as much of the cabin's side of the firewall as possible, A-pillars (help kill wind noise), roof. Don't have to do it all at one time mind you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif But as your stereo progresses, that should be your ultimate goal. Doors and floors will also benefit from a layer or two of acoustical foam.
PRODUCTS
DIMENSIONS (if applicable)
PRICE
RAAMmat60 ® V3 (view 1) - (view 2) 50' x 1.25' x 60mils (62.5 sq ft) $99.00
V&S 1081 aerosol spray can (12 oz) $8.95
Ensolite MLC ® 1/8" x 56" x 2 yards (minimum)
($9.95 each additional yard) $19.90 / 2 yards
how much is 62.5 sq. ft going to do??? thats not exactly cheap
especially if i screw it up or something...
LOL.......not cheap? 36sqft of Dynamat Extreme (Dynamat's comparable product) costs $250. Which means 62sqft of Dynamat Extreme would cost $500......which means the Raammat costs 80% less than the "mainstream" brand //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif And if you e-mail Rick (the owner of Raammat), you'd likely be able to get him to sell it to you for $79 + shipping.
I was able to do 1 layer on my entire trunk (walls, floor, rear by taillights and trunk lid) and 3 layers on my drivers door with one roll.
Take some rough measurements of your car's interior where you want to place the material, you'll get a decent idea how much you need. 62ft isn't enough to do an entire car, but it'd do several key places, depending on the vehicle of course.
And, normally I agree with squeak, but I disagree using a sub at relatively low levels wont loosen the suspension. Again, check the pro's that test these things, they don't push these things hard to break them in. A spider for example will still loosen up even with less than full range of motion.
This isn't rocket science, its mostly common sense. The subs will tell you when they are unhappy, you just have to listen for it. As I said above, if you do listen for it, you will hear the distortion threshhold change as the suspension loosens.
boomzabit
boomzabit
Minnesota
Apoc
