Xtant 603
Hey guys,
I have an Xtant 603. I have check voltage all the way to the amp and have 14 volts to both power and remote. Once I place the battery line into the amp and test it from the screw it drops to 3 volts. The remote wire is still at 14.
The amp has worked it was a professional install. I have noticed that it'll cut out every now and then sometimes even for days. Last week it went down I check everything including head unit connections, and it hasn't worked since.
My system is Pioneer AVIC-N1 Head unit nothing but line in attached to the brain at this time (ipod). Memphis 6" in the back doors are coming off the stereo. The Amp is powering a Set of JBL componets 5 1/2" front door and an older XTANT 10" for sub.
I have talked to tech support for Xtant he thought my amp just went finally. They want $150 to fix. I like the amp, but not sure if it being gone for a couple weeks for a fix and $150 later if it's worth the hassle.
If anyone has ideas please hit me up palmerrider at comcast dot net or post here.
Thanks apperciate the help,
Don
Never mind this post, got it up and working... My inline fuse (street wires) had basicly cracked at the ends. Looks good when you look at it and it puts some volts out even will hit 14. But, underload it drops to 3.6 and won't power up my amp. Replaced fuse and GOLDEN.
Anybody else have this with other brands?
palmer_rider
palmer_rider
Minneapolis, MN
palmer_rider
