Xtant 403a amplifier pair (two)
  • 4
keep_hope_alive
Premium Member
Acoustics Engineer
Two xtant 403a amplifiers
used in original packaging.
includes high pass and low pass crossover cards with a collection of SIPS.
one RM8 attenuation module
all screws
manuals
$420 shipped for the pair
via UPS
what these amps are capable of?
Frequency Response 5 Hz to 50 kHz +/– 3 dB
Number of Channels 3
Watts per Channel @ 4Ω
2 x 50 + 1 x 100
Watts per Channel @ 2Ω
2 x 100 + 1 x 200
Stereo Ch. Bridged @ 4Ω
1 x 200
Distortion (THD)
Signal to Noise Ratio > 100 dB
Damping Factor > 200 @ 100 Hz with 4Ω Load
Input Sensitivity 100 mV to 8.5 V RMS
Unbalanced Source
100 mV to 17 V RMS
Balanced Source
Input to Line Output Gain 0 dB +/–20 dB,
Selectable in 10 dB Steps
Line Outputs: Yes
Crossover CM12HP & CM12LP Included
Module Ports 4
for Amplifier and 1 for Line Outputs
Power Supply Fully Regulated, Pulse Width Modulated
Operational Voltage 11 to 15 Volts
Fusing No On-Board Fuse
Fusing Requirement 60 Amp
Size (L x W x H) 18.5 x 7.6 x 2.25
the amps have four channel inputs and three channel outputs. i'm selling them as a pair because they are PERFECT for a 3-way active front stage. you have 50Wx2 for tweeters, 50Wx2 for mids, and 100Wx2 for midbass - and the power is very clean.
you can assign any crossover or pair of crossovers to any channel pair. no limitation on what channels can do, and jumpers allow for easy bypass when used with an external processor.
They didn't sell on eBay?.. wish that had more power..
they are still on ebay. i just got a message on eBay asking to sell just one. I revised the auction to be just one amplifier and will create another auction if someone wants. otherwise, i'll just sell one and keep the other for the wife's car. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
"more power" is relative. the THD is so low on these amps, it's plenty of power. and the power supply can actually keep up. keep in mind some amps can be rated such that only once channel is capable of providing rated output at a time due to the power supply losses - and also note these are fully regulated so you don't lose output just because supply voltage drops. it got louder than I ever needed and didn't get close to clipping. anything louder isn't SQ and is into hearing loss range anyway.
  • Locked
COMPLETED Xtant XIS 2.4
Also looking for the crossovers
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
491
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
923
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
keep_hope_alive
