Xplod 760
tonyroc14
V8 FTW!
As some of you may know i bought a Kicker CVR and i love it, but i hate my amp.
It overheats so much, even with the new box. I have my gians down. The only thing i can think of is the cable. I think it's 12-16 guage going from amp to terminal, but terminal to sub is 8. I dont want to buy a new amp, i know this one sucks, but i think it should at least power this ONE sub fine.
EDIT: running it at 4ohms
it's not your speaker wire.for one, what impedance are you runnin the sub at. depending on the impedance you could be stressing the amp out which can be causing it to heat up.
oh yea, one crucial part of the equation. Im running it at 4ohms.
what do you mean back to a distro block??
because i have two amps. And then they run to a distro block, and then to 4 guage ground. So i only need one grounding. it goes like this
+--4 guage--distro block---8guage--2 amps---8guage--distro block---4 guage--ground
you have a seperate distro for ground and power?? you don`t have the actual ground going from one amp to the other then grounded to the car do you.?? couldn`t really understand what you said last
be back in 10 mins to reply back LOL smoke break
most likely you`re gains are to high or you have the bass to high then.
If you're going to criticize other people for using the wrong version of your/you're, perhaps you should learn the difference as well. And learn where the **** apostrophe is on the keyboard
i have it right now wherei want it. It isn't clipping and i can hear it in the car. If i turn them down anymore, then i can't hear it inside the car....//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif i think i just need a new amp. This one doesn't have enough power for my aplication, plus it's shit...
tonyroc14
V8 FTW!
tonyroc14
lahabra ca
miker
