WWca.comD
MutantDreams
I just want to know, what would caraudio.com do in this situation. I'm up for all reccomedations.
I have a 08 scion tc with the factory sub, and I want to do a pretty simple setup. I work at a gps tracker company, so I have got to have trunk space for my toolbox, however if a sub setup can justify me having to lose all if my space, so be it. I plan on running the factory 140-160a alt, 2 duracell group 24/34 Agm batteries, and around 1k on the sub. In my previous car (08 cobalt) I had two re audio ***-15's, off of 1500-2000, and it was loud, I just had to lose the back seats. So here is what I need. I am kinda picky, I want to keep all the amps the same brand. I would like to run an active setup, but am not sure yet.
1k ish sub amp
70rmsx4 4ch
70rmsx2
A sub around the ratings of the sub amp,
The newest "in" wire. Back on my last build it was knu& welding wire.
Tl;dr: need amp and sub reccomedations for scion tc.
So your going to go with a sub stage on 1000wrms and completely disregard your front stage keeping up?
Also you can save some money by skipping out on those batteries. On 1K a good battery in the engine bay and maybe the big 3 should be plenty to keep your voltage up.
I already have the two batteries from my cobalt, and I'm hoping an active front stage on 70-100w should be fine, but I'm no pro at that. Oh and I already did the big 3 in my scion with 0/2 gauge welding wire I had left over, more than likely I'm going to sell the other battery I I won't need it.
Edit: also I forgot too add I already have kicker cs components that were ran on a rockford 150.2
What headunit are you going to use for active processing? Or did you plan to do that with your amps? Budget?
I have a 80prs, but right now it is just factory , I plan on putting it in once I have a little time.
And it depends on a few things. I was thinking of running the hifonix 5ch or a belle series 5ch, because realistically it would be cheaper. But here is my budget, might be able to wiggle a bit.
Sub: $150-200
4ch: $100-150
Sub amp:$150-200
Wiring:$200 for everything.
If I find better components I'd be willing to spend $250-300
If I went with the hifonix 5 ch I'd save about $100 which I can put towards other things.
MutantDreams
MutantDreams
Columbus, Georgia
MutantDreams
