WTTF: SQL d2 or d4 12" sub or head unit
WashYourWinky
The Pilot
I need a new sub stage. D2 or D4 12" SQL. I could also use a new head unit, USB is a must!
I've got a few things to barter with.
Diamond D6 600.4
Cosmetic 8/10 Mechanical 10/10
Specs: http://www.diamondaudio.com/manuals/d6_amplifier_manual-2005.pdf
Tantrum 500.2 Specs:
Mechanical 10-10 Cosmetic 8.5-10
Thermally Efficient Heatsink
Timed Acoustically Integrated Muting (TAIM)
Differential RCA or Speaker Level Inputs
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
18dB / Octave High Pass or Low Pass Crossover
40Hz to 800Hz Continuously Variable Crossover Frequency
Auxiliary Outputs Route Inverse Crossover Signals
Variable Twin-"T" Bass EQ Circuit Provides Up to 18 dB of Boost at 45 Hz
Optional RMD Remote Monitoring Display Port
Optional LPL Low Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
Amplifier Type: 2-channel
RMS Power: 125W x 2 @ 4 ohms
RMS Power: 250W x 2 @ 2 ohms
Bridged RMS Power: 500W x 1 @ 4 ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
alec14
