WTT/WTS Kicker SX500.2 & 600.2 with built in digital dsp
gentlejax
I need a 5 channel amp instead of 2 for space reasons
I put these both in today and I have come to realize for what I need a single amp is going to benefit me more. I use my trunk quite a bit for work and I dont want to damage whatever amp is in there and with these 2 there just isnt enough room for all my trips to Home Depot for work.
I need to go back to a 5 channel or 3 channel amp
details
SX600.2 has roughly 5hrs time on it. was new and sealed when I got it last week. Comes complete with everything in mint shape. Was originaly purchased at Crutchfield but not by me....Birthed @ 640 watts rms
specs off net:
# Kicker SX600.2 2-Channel Amplifier with DSP
# 32-Bit User-Programmable Digital Signal Processing
# RMS Power Rating:
* 138 watts x 2 channels @ 4 Ohms
* 275 watts x 2 channels @ 2 Ohms
* 550 watts x 1 channels @ 4 Ohms Bridged
# UltraMatch Gain Structure, single-band parametric KickEQ (Variable Gain, Boost, and Q), and crossovers ( Variable High and Low-Pass Filters )
# SAMS (Stereo And Mono Simultaneously)
# ISIS (Indicate Status & Input Settings) Interface
# BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
# Kompressor
# Adjustable Phase Control: 0 - 180°
# EndKaps: Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier
# SickBay and On Board Diagnostics
# Frequency Response: 20 Hz - 200 kHz
# Variable Input Sensitivity: 1V / 2V / 4V / 8V / 16V
# Signal-to-Noise Ratio: >100 dB
# MOSFET Power Supply
# RCA Outputs: 1 Pair
# Remote Gain Control
# Fan Cooling
# Dimensions (With Endcaps): 22-1/2" L x 10" W x 2-1/2" H
SX500.2 I got this used off a guy online and it now reads 36hrs total play time....it has a few scratches on the endcaps but topside and amp itself looks great and works great.
Birthed @ 542 watts rms
specs
# RMS Power Rating:
* 125 watts x 2 chan. @ 4 Ohms
* 250 watts x 2 chan. @ 2 Ohms
* 500 watts x 1 chan. @ 4 Ohms bridged
# Fully adjustable High- and low-pass crossovers with variable slope and crossover frequency
# Fully adjustable EQ single-band parametric equalizer with variable Q (width), variable frequency and variable boost or cut
# Adjustable channel output phase; left and right channels can be linked or independently adjusted
# Left and right channels can be adjusted together or separately
# On-Board Diagnostics tools to troubleshoot installation problems and check amp status
# Four-setting, user-selectable bass compressor to phatten up your sub bass and adjust to compensate for speaker size, speaker location, vehicle size or listening style
# Low Impedance Operation
# Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal) protects amplifier from accidents, out of spec operation, and misinstallation
# MOSFET Power Supply for high power operation
# RCA output jacks to pass the incoming signal to another amplifier or component
# Allows bridged mono load and a stereo load at the same time. (Not available on mono amps)
# Remote Bass Level Control, and control of signal transfer between multiple SX amplifiers
# Amp Strapping lets you put two mono amplifiers together into a single unit with double the power
# Removable aluminum endcaps protect and hide all your wiring to amp for a clean installation. Leave them off if you need a few inches for clearance or if you like the way it looks.
# Dimensions (With Endcaps): 19-1/4" L x 10" W x 2-1/2" H
I like these amps but I barely had time to through in a quick messy install much less a nice one with them on a rack or something. the DSP is a very nice thing...takes out the guesswork....
I will split or sell together at a discount.
I have 1 manual and 1 printed manual...both boxes and all endcaps.
SX500.2 asking $140 shipped ...prices online vary from $199-359
SX600.2 asking $175 shipped ...prices online vary from $259+
gentlejax
gentlejax
Bossier City, La.
gentlejax
