WTT TC Sounds TC9 for APCL 150001d or comparable amp.
WS6TA
This 12" sub comes with a passive radiator. It is designed for a 2.3 cu ft box when used with the radiator which make it perform like a ported box without the noise. This system is practically new only been connected for a few minutes on 300w to verify functionality because I got it in trade. Even on 300w it sounded tight, loud and played very low. This sub can also be used in a .75 cu ft sealed box and will still sound amazing. I have another sub that I need an amp for so this one needs to go.
I am looking for an amp that will put out 1500w rms @ 1 ohm. I've been looking at APCL 15001d and DSC 1500.1d. I would be willing to trade straight across for an amp of equal or better quality and or specs.
You can text me at 503 899 7903.
What value to you put on ur items?
Depends on what you have to trade for it and how much urgency I have to let it go. Right now it's value is the same as a true 1500 watt RMS @ 1 ohm amp. If I sell other things first and buy the amp I need then urgency to trade/sell this item will be lower therefore the value will go up considerably.
WS6TA
WS6TA
Newberg, OR
WS6TA
