WTT: TC 12's, Knu RCA's, Distros and more
SPY
Well I've had some interest in this stuff but mostly from people with no money so I figured I'd see if anyone had anything they wanted to trade for it.
I'm open to pretty much anything of decent or better quality car audio wise, Wii games/accessories, Xbox 360 games/accessories, Paintball stuff, tools, anything else interesting....
1. Product:
TC sounds DB500 Pair
2. Specs:
Introduction
Never again will you find a better driver for less money! The all new dB-500, offers you the absolute most bang for your buck that we can possibly provide. This amazing entry driver shares many of the TC-1000's defining features including the beefy 135 ounce high performance motor, a high thermal four layer aluminum 2" voice coil, and up to 2” peak to peak excursion. This driver is built to last and we construct each with the same standards as our high end speakers. The dB-500 simply can’t matched for this modest price and best of all, we're still building this driver in house right here in San Diego California.
Specifications
Advanced FEA Motor System
• Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
• 135oz top grade magnet structure
• Anti-flux modulation copper shorting ring to lower distortion (12" only)
• Low carbon steel used for the gap plate and t-yoke
• Pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
• High excursion 8.5" linear roll poly-cotton spider
• Intergraded woven leads to prevent lead-slap
• 2" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
• Single or dual 3.4Ω (4 ohm nominal) voice coil configuration
• Lightweight brushed and powder coated aluminum cone (12" only)
• 1" wide long throw, highly durable NBR surround
• High quality thermal flexible epoxies to ensure longevity
Performance
• Effective motor force of 50 Newtons2 per watt (BL2/Re)
• 400 watts continuous power (1000 watts peak)
• 20mm BL XMax (voice coil, one-way)
• 34mm XMech (mechanically limited, one-way)
12" dB-500 SVC
Qts 0.447
Qes 0.481
Qms 6.347
Fs 24Hz
Res 3.25Ω
Ls 2.36
Lp 3.51
Rp 2.91Ω
Dia 241mm
Vas 71.5l
mms 169g
cms 244um/M
bl 13.3Tm
Spl 86dB
1.4-2.8ft^3 sealed or 2.2@32 hz (small) or 4.0@22hz(large) each recommended box size.
3. Description/Condition:
Used but in good condition
4. Price: :
There is something else I want to buy so I'm selling these for $150 shipped, if the other item sells before these do they will go back to the original price of $150 + shipping.
5. Pictures:
1. Product:
Knu KonFUSED 2 Way Digital Distribution System
2. Specs:
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-22D has Two input ports, which by changing the Kompression Fitting, can accept 4 Gauge or 1/0 Gauge Cable. The output side can be adjusted to accept 4 Gauge or 8 Gauge cables. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-22D can maintain loads up to 150A per circuit.
The Digital Display is illuminated by Blue LED's and requires a ground wire to be connected to the base mounting screw on the output side of the block
Used but in good condition, I have some fuses I will include as well as some other compression fittings. PM me with what you want for input/output fittings and fuses and I'll see if I have it. Pics show the fuses and fittings I have but they do not all come with this sale, they will be split up between this and my other distro block sales.
4. Price: :
$18 + shipping.
5. Pictures:
1. Product:
Knu KonFUSED 3 Way Distribution System
2. Specs:
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-23 has two input ports, which by changing the Kompression Fittings, can accept 4 Gauge or 1/0 Gauge Cable . The two of the three ouputs can be adjusted to accept 4 Gauge or 8 Gauge cables while the last output can be configured for FUSED 1/0 or 4 gauge output . The KNF-23 has 18 Unique Konfiguratons. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-23 can maintain loads up to 150A per circuit.
4. Price: :
$15 + shipping.
5. Pictures:
4g set screw type ring terminals. I believe thay are Stinger HPM but I'm not positive.
2. Specs:
Accepts up to 4g wire
4. Price: :
$5 + shipping
5. Pictures:
1. Product:
Knu Krystal Kable Twisted Pair Y Adapter 1M2F
2. Specs:
The Krystal Kable is the Fort Knox of cables. These cables feature 4 different types of sheild / noise rejection all in one cable!. Features Include:
Twisted Pair Balanced Audio Signal
Copper Foil Sheild wrapped Audio Cable
Second Inner Layer PVC Jacket
Mylar Foil Sheild
Tinned Copper Braid Covering 98% of the surface area
High Quality Metal Ends with Diagonal Kut Konnection
This cable is 12" Long and has One Male and Two Female ends
4. Price: :
$8 + shipping for the pair. Not willing to split up.
5. Pictures:
1. Product:
Stinger Hyper 1m and Y RCA's
2. Specs:
1m RCA is 1m and the Y is 1m to 2f :dontknow:
1m is used but in good condition and the Y is BNIB
4. Price: :
$5 + shipping for the pair or $3 + shipping each.
5. Pictures:
1. Product:
LA Storm Distros
2. Specs:
These used to be used when power caps were big. This will connect 2 caps and allow distrubution of both the + and - wires.
Used but includes original packaging and is in good condition.
4. Price: :
$10 + shipping
5. Pictures:
1. Product:
Knu Krystal Kable 2 Channel 1/2M Twisted Pair RCA Cable
2. Specs:
The Krystal Kable is one of the best cables on the market. It is the Fort Knox of RCA cables. This cable contains 4 different types of shield / noise rejection characteristics all in one cable!. Features Include:
Twisted Pair, Copper Foil wrapped Audio Signal
Sub-Layer PVC Jacket
Mylar Foil Shield
Gold Plated Metal Ends with Diagonal Kut Konnection
The 1/2 Meter (18") Cable is finished in a rugged translucent smoke color PVC.
BNIB, I bought these for my install but they ended up being too short so I had to order 1m's
4. Price: :
$12 + shipping for both or $7 + shipping each.
One SOLD one left
5. Pictures:
1. Product:
MTX X-over Model RT-XO1A
2. Specs:
2ch
RCA or speaker level inputs
Adjustable high pass/low pass and level controls
Older model, a little scratched up but works well.
4. Price: :
$15+ shipping
Should fit in a USPS small flat rate box
5. Pictures:
LA X1.15.VC2 for the DB500s + cash? I know you want the top assembly, and you could sell the motor //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
(that is, if the DB-500s are DVC)
They are SVC 4ohm
Pm me with how much cash you'd want if your still interested.
SPY
SPY
NY
SPY
