dross93ranger
1. Product:
Sundown SAX-1200D
2. Specs:
The SAX-1200D is the successor to the SAZ-1000D model - it features a newly tooled board taking advantage of newer and more powerful MOSFETs to achieve 20% more power in a casing only a little over 1/2" longer than the SAZ-1000D model that it replaces. Don't let the small size fool you, this amp is a little power-house!
The SAX-1200D is the perfect companion for a pair of SA-10s, 12s, or 15s.
Rated power output ----RMS power, 2 ohm linkable/dual mono2160W x 1CH----RMS power, 1 ohm mono1200W x 1CH----RMS power, 2 ohm mono720W x 1CH----RMS power, 4 ohm mono360W x 1CHSignal to Noise Ratio >90dBLow pass frequency crossover 35Hz~300HzSubsonic filter 10Hz~60HzBass boost @ 45Hz 0~6dBPhase shift control 0~180 degreeFrequency response 10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm
Rated power output
----RMS power, 2 ohm linkable/dual mono 2160W x 1CH
----RMS power, 1 ohm mono 1200W x 1CH
----RMS power, 2 ohm mono 720W x 1CH
----RMS power, 4 ohm mono 360W x 1CH
Efficiency @ 4 ohm 86%
Fuse rating 40A x 3
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 310(L)mm
3. Description/Condition:
Cosmetic - 9/10, looks almost new, mechanically 10/10
4. What you are looking for: :
I am looking for an amp that will push 1200+ and cash, or a 1200+ amp with another small mono amplifier, S10 lowering coils, 8" sub that will fit behind the seat of a single cab 99 S10.
The trade must include an amplifier that will push atleast 1200w.
*There is no cash price on this amp, but feel free to offer
5. Pictures of your item for trade:
I can get a pic asap with my user name.
Sundown SAX-1200D
2. Specs:
Rated power output
Fuse rating 40A x 3
