WTT: Soundstream Dtr1.3400
bgowdy
Heroes are remembered, but legends never die
Theres nothing wrong with the amp. i like the amp in everything. just would rather have power at 1 ohm. i dont have the electrical system to run a .5ohm load. so wanting to trade for power @ 1 ohm. any questions feel free to ask....
heres the only pic i have right no, will upload more when i get off work:
Start of 4th order wall - CarAudio.com Rides Gallery
oh yea:
Soundstream D-Tower Series Monoblock Class D Car Amplifier
RMS Power Rating:
0.5 ohm: 3400 watts x 1 chan.
Full MOSFET Power Supply
The worlds first vertical automotive stereo amplifier
Double side PCB and SMD components
LED power (green) and protect (red) indicators
Monoblock operation
Gloss black finish w/ brushed accents
Dash mounted remote gain control
3-Way System Protection circuitry (thermal, short, impedance)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (10-50 Hz)
Variable low-pass filter (40-220 Hz)
Subsonic Filter (10-50 Hz)
Bass boost frequency: 30-90 Hz
Bass boost level: 0-12 dB
Signal-to-noise ratio: >85 dB
THD (Total Harmonic Distortion): 0.5%
Damping factor: >200
Frequency response: 10-220 Hz
Dimensions: 17-3/4"L x 3-5/16"W x 7-1/2"H
i bet you would trade me wouldnt ya?
lol.... na... looking for something in the 2500rms @ up margin... i found a beast amp on here. try to see what the guy wants for it
---------- Post added at 06:03 PM ---------- Previous post was at 06:03 PM ----------
***2500 & up......
so the clamped 23 out of mine isnt enough? lulz ill be grabbing the blown one from corey soon enough. if you want it after i repair it ill give it to you for what i paid+repairs. that is if you want.
i knows the db's are beast. just trying to get as much power as i can. the one i seen like 3k @ 1 ohm.
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
