up for sale yet again is the trf, i traded it off for a while, and ended up getting it back. Shes seen her better days, mechanically its still 10/10 spyders are just broken in, i beleive it has 3 stiff 9.25" spyders. leads are direct connect and comes wired at .70 with ~8ft of stinger 8ga on each lead. i ran this at .70 on an adassa 5k, and it was ran after i had it on a proto rf 4000bd @.70. coils are d1.4. as for issues, the surround had a couple cracks from the glue on the underside being applied too high. i chipped away most of it and repaired the cracks with black rubberized glue from PSI, who also build the original recone in May 2010(dated on the cone), other issue is that the basket has 3 re-drilled holes, the old holes were rattled open to the size of a screw head. the sub is still structurally sound.
LOOKING FOR:
MMATS 4000HD/ 4000.05
2 AudioPipe 3ks
or any amp that will run daily with at least 4k@ 2.8 or .35
LOOKING FOR:
2 AudioPipe 3ks
