Rockford Fosgate T3002 Class A/B
pretty much new I haven't even used it yet.
Specs:
Amplifier Type: 2-channel
12dB or 24dB/octave selectable crossover
2/4 channel switch
4 Gauge Power/Ground connections with built-in ATC fusing
Audiophile grade amphanol speaker connections
Best in class 4 oz. copper traces
MasterSync
PowerSync
Stealth Connections
50 W x 2 @ 4 Ohms RMS
100 W x 2 @ 2 Ohms RMS
150 W x 2 @ 1 Ohms RMS
200 W x 1 @ 4 Ohms bridged RMS
300 W x 1 @ 2 Ohms bridged RMS
Now everyone knows this is one of the most UNDER RATED amps out. I believe this one did a little more than 850 x 1 @ 2 ohms bridged. I lost the birthsheet but remember it doing those numbers.
Description/Condition:
10/10 mechanically
9.5/10 cosmetically only cause it has a small scratch on the bottom...nothing a lil paint can't fix up
I need a mono amp that does 1000-1200 at 1 ohm and AT LEAST 600 at 2 ohms. If good enough amp I will add money on my end which I will in most cases. Might even be interested in 1500 watt amps. LMK
5. Pictures of your item for trade:
Specs:
2/4 channel switch
MasterSync
PowerSync
Stealth Connections
10/10 mechanically
