WTT: Poker Play for Stereo Install
WhoSayWho?
Preston Caught a Predator
I am a better poker player than I am a stereo installer. If there is anyone for whom the opposite is true I would propose a trade.
I have some stereo equipment I need installed. If you would be willing to install it, I will be happy to play online poker (with your money) while you work on my ride. We can work something out on how we split any winnings.
Thanks.
dang, that may be a deal breaker there. I am thinking about getting a lot of those mofo's. Only problem is I amy not be able to amp all of them. I wonder if the unamped ones were close enough to the amped ones they would act as passive radiators.
they might. but if we make a relly big box for them all and wire the amps in series parallel and use AC voltage to power them, the coils will coordinate into a 4 ohm load no matter what. all amps can handle 4 ohms. so therefore you only need two amps and you can run an infinite number of subs.
EDIT. the box MUST be sealed other wise it will let the rear wave of the sub escape creating a turbulance in the vehicle the will upset the structural integrity of the subwoofer suspension causing mechanical failire in your amps.
EDIT. the box MUST be sealed other wise it will let the rear wave of te sub escape creating a turbulance in the vehicle the will upset the structural integrity of the subwoofer suspension causing mechanical failire in your amps.
lol, good night my friend.
WhoSayWho?
WhoSayWho?
Hempstead State Park
WhoSayWho?
