bgowdy
Heroes are remembered, but legends never die
I wasnt trying to make a new thread but couldnt find the old one for some reason.... oh well.
Like the title says Old Style Mojo 4KW. Just looking to try something different.
Im looking to trade for a 3k - 4k amp depending on what it is so just offer up what you have and are interested in trading. Will add more pics when i get a break.
Amp pic- Memphis Mojo 4k - CarAudio.com Rides Gallery
OS Guts- OS Memphis Mojo 4KW Guts - CarAudio.com Rides Gallery
If you need to know:
Memphis 16-mcd4KW
RMS Power Rating:
4 ohms: 1000 watts x 1 chan.
2 ohms: 2000 watts x 1 chan.
1 ohm: 4000 watts x 1 chan.
Max power output: 4000 watts x 1 chan.
Total Harmonic Distortion:
4 ohms: 0.5%
2 ohms: 0.75%
1 ohm: 1.0%
MOSFET power supply
Remote bass level input (remote level control sold separately)
Power, protection and blown fuse LED indicators
Custom black pearl finish
Signal To Noise Ratio: 95 dB
Input Sensitivity: 250mV - 9V
Input Impedance: 22Kohm
Damping Factor: >50
Output Impedance: 1-4Ohm
Includes 0 gauge fuse holder with two 250 amp ANL fuses
Low heat generation
Gold-plated RCA inputs
Buffered RCA low level output (loop through)
Variable low-pass filter (50-250 Hz, 18 dB/octave)
Variable high pass subsonic filter (20-50 18dB/octave)
CEA-2006 compliant amplifier
Dimensions: 31-1/2"L x 7-5/8"W x 2-1/2"H
Memphis 16-mcd4KW
RMS Power Rating:
4 ohms: 0.5%
2 ohms: 0.75%
1 ohm: 1.0%
MOSFET power supply
Damping Factor: >50
Low heat generation
