WTT: Orion Xtreme 400.2
2loud4youmorris
1. Product:
Orion Xtreme 400.2
2. Specs:
Power Output 4 Ohm Mono: 400 Watts
Power Output 2 Ohm Stereo: 200 Watts
Power Output 4 Ohm Stereo: 100 Watts
Frequency Response: 20Hz to 20 kHz 0.25 dB
Linear Bandwidth 6Hz to 50 kHz 3dB
Signal-to-noise ratio full bandwidth @ rated output power: >100 dB
Damping factor @ output connector full bandwidth >400 at output connector
Input sensitivity: 200 mV to 5 Vrms
Fuse type: (2) 20 AMP ATC
Low-pass crossover: Continously variable
Low-pass frequency range: 45 Hz to 5 kHz
High-pass crossover: Continously variable
High-pass frequency range: 10Hz to 1 kHz, 100 Hz to 10 kHz
High-pass "Q" range: Continously variable from 0.707 to 3.5(0dB to 10dB)
Dimensions: 12" x 10.25" x 2.25", 305mm x 260mm x 57mm (L x w X H)
Orion XTREME400 Orion XTREME 400 2 Ch 400 Watts amplifier
3. Description/Condition:
8.5/10 cosmetically its just dirty
10/10 mechanically
4. Price: :
$130 + shipping
5. Pictures:
2loud4youmorris
2loud4youmorris
Caro, Michigan
2loud4youmorris
