Sub is in excellent shape. 600 rms sub.
I need a 4 channel amp that does 50 - 100 watts x 4 @ 4 ohms
Possibly, but is it the same amp that you mention here?Got a Cadence TXA3004 BNIB and warranty card that needs filled out. Does 75x4@4 and under rated.
and if not, have you had problems with this?Have a quick question about amp whine. I may trade a perfect 06ZX150.2 for a Cadence TXA300.4 I need a 4 channel and the guy Id trade with needs a 2 channel. Now he says it whines and he broke off an RCA in one of the inputs. Is it possible for that broken piece to cause the whine or is it unlikely?
I just purchased a BNIB TXA3004. Have everything in the wrapper. I pulled it out to take some pics and check it out. Make sure it was ok from shipping. I noticed the terminals for power and ground are rather smaller. It does 75x4@4 and has 2x25a fuses. Now my question is who knows what gauge power wire and ground wire I will need for this? I think its 8 gauge, but Im not sure. It requires voltage between 12.4-14.4 to run right. Anything higher and it will blow and anything lower it will shut off.
