Like the title states, i want to trade this sub and amp combo for a larger amp( REALLY LOOKIN FOR SOMETHING TO PUCH 3000 @.5 OHMS). I'll get pics later tonight, heres some of the specs on the equipment.
EDIT: I can add cash as well, but would prefer not to //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Kicker L7 10"
Subwoofer Size 10"
Dual Voice Coil Yes
Impedance 2 ohms
RMS Power Handling 600 watts
Peak Power Handling 1200 watts
Woofer Surround Santoprene Rubber
Woofer Composition Mica Filled Polypropylene coated with Titanium Deposit
Sealed Box Volume 0.66 – 1.0 cubic feet
Ported Box Volume 1.25 - 2.25 cubic feet
Sensitivity 86.1 dB
Frequency Response 24 - 100 Hz
Xmax (millimeters) 13.2 mm
Top Mount Depth 6-3/16"
Cutout Diameter 9-7/16"
Fusion 2500.1 D
825 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1310 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1790 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
Max Power Rating: 2500
Max Current: 218A
Full Rated Power Distortion (Max) 1kHz: 0.43%
THD @ Rated Power 1kHz/100Hz: 0.3%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 24 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47K
Fuse Rating: 200A External
Just throw some stuff out there, i don't need this stuff anymore
Kicker L7 10"
Subwoofer Size 10"
Dual Voice Coil Yes
Impedance 2 ohms
Sensitivity 86.1 dB
Fusion 2500.1 D
Max Current: 218A
