wtt:mtx1501d
blkmrideon22s
i want to trade my mtx audio 1501d for a fi bl 18 daul 1 ohm full loaded.so if anybody has one let me know.
THUNDER1501D
• RMS Power measured at 12.5 Volts DC:
500 Watts x 1 into a 4 Ohm load with less than 2% Thd+N
1000 Watts x 1 into a 2 Ohm load with less than 2% Thd+N
• Dynamic Power measured at 14.4 Volts DC:
750 Watts x 1 into a 4 Ohm load
1500 Watts x 1 into a 2 Ohm load
• Signal to Noise Ratio: ≥100dB A-Weighted
• Damping Factor: >100
• Frequency Response: 20Hz-200Hz ± 3dB
• Maximum Input: 8Vrms
• Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
• Crossover: Variable 40Hz to 200Hz, 24dB/Octave Low Pass
• Dimensions: 17.8" x 9.75" x 2.1" (45.3cm x 24.8cm x 5.3cm)
blkmrideon22s
blkmrideon22s
Boone NC
blkmrideon22s
