WTT: Kicker KX150.2 for a HU!
WashYourWinky
The Pilot
Picked up this Kicker KX150.2 on a trade and don't really need it, I could use a HU though! May trade for a Rockford amp with around the same specs.
Specs:
# 2-Channel KX-Series Power Amplifier
# Low Impedance Operation
# SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
# MOSFET Power Supply
# KickBass: 0-18 dB @ 45 Hz
# Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
# High & Low level inputs
# PAST (PRE Amp Signal Transfer) Output RCA jacks
# Custom tooled gold plated connectors
# SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
# Cast aluminum EndKaps
# RMS Power Ratings:
* 14.4V:
o 60 watts x 2 chan. @ 4 ohms
o 75 watts x 2 chan. @ 2 ohms
o 150 watts x 1 chan. @ 4 ohms
* 12.5V:
o 30 watts x 2 chan. @ 4 ohms
o 60 watts x 2 chan. @ 2 ohms
o 115 watts x 1 chan. @ 4 ohms
# Input gain control: Low Level (170mV - 5V), High Level (340mV - 10V)
# Dimensions: 12-3/4" L x 10-1/8" W x 2.5" H
Amp is in awesome condition mechanical 10/10 cosmetic 8/10
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
TKCARAUDIO
