WTT Kenwood Amp for 10" Sub
I still can't get a mod to help me. I messaged a couple of them and still no response. I was able to get these two pics in before I got denied. i am just hoping to get some help. I am new to this, so it could still very well be my fault.
Its not your fault, you aren't doing anything wrong. The forum has anti-spam software that wont allow someone to post pics until they have a certain number of posts (10 iirc). But that software appears to be buggy, as we receive messages from new members sometimes saying they are being denied the ability to post pics, even though their post count is above 10 (but still fairly low, like yours).
There is no moderator post approval system here. We have no way to approve or deny posts, as that error message implies we do. I apologize for the inconvenience, my best/only advice is to keep trying to post until they go through. Usually a new member with this issue just has to hit a certain post count, and they are fine. But it appears to be a hit or miss in your situation.
Again I apologize for the issue. We are eagerly waiting on a software update to hopefully fix this problem.
Thank you sir!! here I go again. I wasn't able to get pics of the other side of the board without havin to start bending metal tabs and stuff, so the above pics are about all I could get. It's got pretty low THD and 60 watts x 4 RMS at 4 ohms. Here is the link to the amp specs.
link
---------- Post added at 07:30 AM ---------- Previous post was at 07:29 AM ----------
linkhttp://www.sonicelectronix.com/item_430_Kenwood-KAC-8401.html
---------- Post added at 07:30 AM ---------- Previous post was at 07:30 AM ----------
The KAC-8401 is a multi-channel power amplifier that's powerful enough and versatile enough to run almost any speaker configuration. Power output is 60 watts x 4, 180 watts x 2 (bridged), with a maximum outpu rating of 640 watts. The power MOSFET switching power supply uses two large secondary capacitors and a large toroidial noise filter. Features include selectable +6dB bass boost (90Hz), variable low-pass and high-pass electronic crossovers for the A and B channels, 2-ohm stability, speaker level inputs, a Quiet Turn-On circuit, and a cast aluminum heat sink with sandblast finish.
FEATURES
Cast Aluminum Heat Sink: with Sandblast Finish
Power Indicator: Blue Logo Triangle
Bridged Power Output at 14.4V (1kHz, 0.8% THD): 180 Watts x 2
Maximum Output Power (Bridged): 640 Watts
Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 90 Watts x 4
Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 60 Watts x 4
4, 3, or 2 Channels of Amplification
Ground Isolation Circuit
Input Selector: AB/A (Common)
Quiet Turn-On
RCA Audio Inputs: Gold-Plated
RCA Line Outputs: Gold-Plated
Speaker Connectors: Gold-Plated, Screw-Type
Speaker Level Input Terminals: Plug-Type
Stereo, Left + Right, Mono, or Tri-Mode Operation
Variable High-Pass Electronic Crossover: 50Hz - 200Hz, 12dB per Octave, A and B Channel
Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 12dB per Octave, A and B Channel
Bass Boost: Off/+6dB (90Hz)
2-Ohm Stable
Copper EE-Core Power Transformer
Noise Supression Filter: Toroidal
Power Input Terminals: Gold-Plated, Large Screw-Type
Power MOSFET Switching Power Supply
Power Supply Fuse: 40A
Secondary Capacitors: 2
1-year SonicElectronix.com warranty
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
assassin1840
